RX1Jim
What do you guys do to check the drive axle bearing (speedometer sending unit side)? I had one of these bearings fail on a long tour in Quebec on my 2000 SRX 2 years ago. Since I have not used the 00 SRX and my 03 RX-1 in two years, I going to change these bearings just to be on the safe side. When the bearing failed it ruined the axle and one of the bearing retainer plates. Some have suggested popping the seal out on one side of the bearing, cleaning out the old grease and repacking it with a quality synthetuc grease. Sure would be nice to have a grease fitting so you could push out the old grease, water and crud a few times per season.
