Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Looking for some experience on installing a new axle, mine broke!
I see 2 set collars on the outside of the end drivers, and no set screws or collars for the 2 middle ones, are these drivers a press fit! And if so what is the trick to installing it on the sled? The broken shaft came out after removing the speedo side bearing, does the whole chaincase, inner and outer halves have to be removed for installation?
Thanks, Bob
Thanks, Bob
