driveshaft bearing metal seal?
No. About all you could do is using a very small grease needle try getting it in.
When you need to grease it just pry it off. You will destroy the seal but it can be replaced with a rubber one from one of your idler wheels. I did this years ago and still works great.
X2.
Another option is to drill a pin hole in the metal seal for a needle greaser and after you fill it with grease clean it good and put a little spot of rubber silicone on the hole.
X2 - I did this but didn't use the silicone. The hole is small enough that very little of anything gets in or out.
