I did a search but could not find my answer in any of the forums. I know this is the apex forum, but know this is looked at more than the others.
Replacing the driveshaft bearing on a 2001 sxr 600. Removed the old bearing which was difficult, stuck to the driveshaft, but successful. Having a hard time aligning the new bearing through the hole in the tunnel. The driveshaft dropped down and towards the back of the hole when the old bearing was removed. Now I can't push the new bearing through the hole because of the tension on the driveshaft and its not in alignment with the hole. I can push the driveshaft up, but not forward where it needs to go. I have the back of the sled on a stand with all the track tension off. Seems like I should be able push the driveshaft without that much resistance. Any ideas?
