Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
That is beyond reusable. The rust on the bearings/cage and the crud on the inside of the seal indicate water has gone in and started destroying the bearing. Lack of grease is also not good.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Mooseman said:That is beyond reusable. The rust on the bearings/cage and the crud on the inside of the seal indicate water has gone in and started destroying the bearing. Lack of grease is also not good.
thanks, that is what I was thinking as well. Anyone have the thread on replacement?
Going to pick up a new bearing tomorrow...........
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Good thing you checked that out before the season started!Apex2006 said:Mooseman said:That is beyond reusable. The rust on the bearings/cage and the crud on the inside of the seal indicate water has gone in and started destroying the bearing. Lack of grease is also not good.
X2 on the thread, I'd like to see that too.
mr.pitstop
There is a thread, lemme see if I can find it..
mr.pitstop
Heres the thread on regreasing. Still looking for the bearing replacement thread
http://www.ty4stroke.com/viewtopic.php?t=52677&postdays=0&postorder=asc&start=0
mr.pitstop
Heres one for changing the jackshaft bearings, not what you wanted but it might help
http://www.totallyamaha.com/snowmobiles/aaTECH/Jackshaftreplace/Jackshaftchange.htm
Heres one on changing the track, talks a little about the bearing
http://www.totallyamaha.com/snowmobiles/aaTECH/Suspension/RX1Track/RX1replacing_track.htm
Hope this helps..
Hope this helps..
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Thanks Mr.Pitstop, appreciate you finding and posting these up!
(all 3 are saved to my fav's)
Apex2006
- Oct 26, 2009
- McHenry, IL
THKSNOW said:That one looks nasty, I say buy a new one. Takes about $30 & 20 minutes to change it.
Hi THKSNOW,
Can you describe the 20 minute process? I was thinking I would have to drop the skid and remove the driveshaft. I ordered the bearing as my dealer did not have one in stock. Thanks!
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
As I recall all I did was the following on my 2006 Attak:
1) buy new bearing
2) loosen the track with sled on stand
3) remove secondary, speedo pickup, bearing cover c-clip
4) With a GOOD allen wrench, remove 2 allen set screws that hold the bearing to the driveshaft, you can see the (2) screws on the inside of the tunnel, take them all the way out. Just rotate the track and you'll see them.
5) I was told the bearing may need some "help" coming off but with 7,000 miles my bearing slid right out and off the shaft. It is not pressed on.
6) Slide new bearing on and replace set screws.
7) Re-install everything and tighten & allign the track
Took me about 20 min., pretty easy job. I don't think I forgot anything, the rest of you please chime in if I did. I did mine before last season started (about a year ago).
Good luck and THKSNOW!
1) buy new bearing
gun nut
16,000 miles on 06 with original bearings. I grease on a regularly.
ITHAPPENS
No need to drop skid or move shaft. Just loosen track, remove secondary(make sure spacers go back same way), remove speedo pick-up and cover, loosen 2 torx on bearing from inside tunnel and use a prybar from inside tunnel to push bearing off towards end of shaft. Should move pretty easy. Make sure to clean and grease end of shaft before re-install of new bearing. Little torx screws should have lock-tite on them for re-install. Like previously stated if you have the correct Torx should take 20min max.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I'd change that one. Then start greasing the new each year.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Not try to steal the thread but has anyone had any luck greasing the bearings on the 06 and up Apex that has the "non-replacable" bearings? I found I could pull the seal off the smaller wheels with the 6205 bearing but not the rear larger wheels.
ITHAPPENS
Re-greased them for 4 years and 12,000kms, never lost a wheel and let me tell you they were almost completely seized at times. Twice a season and finally replaced them with Yam accessory wheels in my final season with the 2006.jaydaniels said:Not try to steal the thread but has anyone had any luck greasing the bearings on the 06 and up Apex that has the "non-replacable" bearings? I found I could pull the seal off the smaller wheels with the 6205 bearing but not the rear larger wheels.
Apex2006
- Oct 26, 2009
- McHenry, IL
THKSNOW said:As I recall all I did was the following on my 2006 Attak:
1) buy new bearing
Thanks THKSNOW,
That sounds like a piece of cake!
- 30K
