fr0st
- Nov 25, 2013
Hey, i've got a female passenger on my 09 xtx last night and noticed that in big bumps the rear suspension got all the way in whcih is pretty hard for the back.
put the side spring on the hardest setting (it was on medium) and it still would do it.
are there any adjustments on the dualshock ?? or maybe it needs to be rebuilt???
can it be rebuilt?? or maybe i should fiddle with the shock in front on the skid instead??
i'm lost here,..
i'm lost here,..
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
try adjusting the compression clicker (stiffer) on the rear shock, it should help. if you ride 2up on a regular basis, you can buy HD springs to compensate for additional weight..... run them soft for solo riding and click it stiffer for 2up riding.
hope this helps.........cheers
fr0st
- Nov 25, 2013
when you say rear shock, you mean the dual shock or the other one ??
fr0st
- Nov 25, 2013
Also is there an adjustement on the dualshock??? i'd like to see if it's not busted or just weak or whatever
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
How many miles on the sled? If she is a few years old with some miles the shocks probably require a service.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
can you take a couple of pics
canoehead
- Jan 14, 2011
- NE, Alberta
Of the girl or the shocks?can you take a couple of pics
fr0st
- Nov 25, 2013
Sleds got 4000 miles
Pis of the girl canmot be shown but assure you its worth it with those D cups and small #*$&@
fr0st
- Nov 25, 2013
Ok i went to take a look at this closer..
the shock i'm talking about is that thing with 2 extending shaft coming out and grease nipples on it.. i don't think this is a shock.. since the're supposed to be 2 shocks in the rear i assume the last one isin't one. so the middle one has a clicker adjustement.. when i turn the dial in all the way vs. the dial all the way out i see a diffrence so the shock seems good... hard to tell for the first one though... either way it's not the source of my bottoming out.
also noticed that the springs are bent funny ....the long part i mean... either modified or from another sled... the previous owner had dialed the suspension ultra soft and had star suspension revalved front shocks. when i picked it up it was like riding on a cloud.. but it could turn at all. and the springs were on the softest settings..
so my 2 cents is.... the previous owner swapped out the springs from another sled to get a softer ride. if i ride 2 i'm gonna need new sprngs and heavy duty ones.. and just set it on the softest setting when solo riding
so the only question remaing is there another adjustement on both those shocks oether than the clicker dial on the second one ???
kurzy
- Mar 25, 2011
- Peterborough On, Can.
- '08 40th. Anniversary Nytro RTX
If they are the stock shocks you should take a look at your manual or find it online. There is a lot of info out there about setup. You will have to familiarize yourself with the suspension on the Nytro. It can be tricky to get it right but you can do it. Figure it out, because it sounds like the previous owner spent some serious $ on it.
