SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
Is there an easy way to get the front shocks back on the sled? You have to compress them a little to get the bolts to line up...
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I assume you are jacking up the front of the sled.SnowBandit said:Is there an easy way to get the front shocks back on the sled? You have to compress them a little to get the bolts to line up...
SnowBandit
- Jan 31, 2004
- Maine
- 2009 Nytro xtx
Yes up on jacks right now... Took shock out and its not going back in easy as it expanded once removed to... Kinda have to compress it to get back in..
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Hmmmm, took mine off to grease the shafts and they went right back on.
boat.man
Disconnect the sway bar and then the suspension will move freely and line up easy.
SnowBandit
- Jan 31, 2004
- Maine
- 2009 Nytro xtx
Maybe I have to jack it up higher...
Tork
Sway bar could be it but not really a factor if both sides are up.
Loosten springs, take tension off to the point when you can jiggle the springs up and down with the front end up.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
High enough to let the ski's dangle.SnowBandit said:Maybe I have to jack it up higher...
