Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
Officially, the season is over and the sleds are home (so now starts my 'honey-do list'). Before I pull the plug and spend a bunch of money on an ECU tune, I was curious to see what mileage everyone has reflashed their sleds at. Realistically speaking, I'd stick to the Stage 1 flash from Precision EFI or either the EcoTrail SM or PowerTrail SM flash from Turbo Dynamics. While 5,700ish miles isn't a ton on these motors, is an ECU tune even worth it at this point?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Why not? Flashed mine at 900 miles. I now have 8000 miles with plans to run it another 8000 miles. You'll have wished you'd done it sooner.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
This is only my second summer with my ' Winder and it's not something that was in the cards last summer - but definitely good to know.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Absolutely. Throttlecrack!
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Tune it!!!! You won’t regret it. I consistently get 15.5mpg on the EcoTrail SM tune. I haven’t measured my gas mileage on PowerTrail or MS16 SM. Seems like much better mileage than stock.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
After your first ride, you'll wish you had done it sooner!
fourload
Tune it. I waited 2 years and did Powertrail SM this year and loved it. Mileage is the same or better than stock. Upgrading to MS 16 SM next year. I suggest you go for a bigger tune like Powertrail or higher to start because you will always be looking for more.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I tuned my spring order sled at 0 km!!!! Never rode a stock winder yet..lol
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
If the sled has enough power to satisfy your needs, stay with stock.
If not, don’t waste your time with that light tune that you can maybe feel the difference of. Have never tried the Powertrail but I run the Max Spool 16, and I promise you will feel a big difference from stock on that one.
I do not have a problem getting non 87 octane in my riding areas.
Mine has been tuned right from new as well...don't know what only 200hp feels like on a Winder.
Fleecer
- Jun 13, 2014
- 2019 SRX
Ya only live once, do it!!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
My vote is for Max Spool 16. Use your thumb when you need less power.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
How long do you plan on keeping the sled? If you're gonna do it, might as well get as much power as you can afford because at some point you're gonna want more. Don't be scared...pull the trigger. It makes a good sled even more gooder...lol
Don't worry about the miles.
I've installed ecotrail on 4 machines this year because guys don't have to worry if they come across a station with 87 only, and it also works good with little to no clutching changes.
