There is a plug, conector tied to the bar by the left side of the sled. You almost have to remove the screws and lift the cover up a little to see it. It has a dummy plug pluged in to seal it. That is the connector they use for the optional 12v accessory plug kit. You can tie in there. Make sure you check for the positive and negative side with a test light or meter.
