faithfullyamaha
- Oct 31, 2014
- minnesota
- 09 phazer rtx
Doing an engine swap cs340ep motor onto a go kart. I have all necessary pieces to simply run the engine, but I need to find a wiring diagram on this thing. Anyone who might have some info or a diagram please comment. No I'm not going to buy a 40 dollar workshop manual for one diagram.
Yamaha Nutz
what are you wanting to know it is pretty simple wiring if you are doing something custom the black/white coming out of the cdi is the kill wire for ignition the yellow out of the stator is you lighting coil which will run your lights and the regulator blue wire needs to be connected inline to regulate voltage cdi hooks up color match to stator wires orange goes to coil out of cdi black out of cdi should be grounded to coil and frame white out of stator is hand warmers and red/white is charge for battery if electric start equipped
faithfullyamaha
- Oct 31, 2014
- minnesota
- 09 phazer rtx
Exactly what I was looking for thankyouwhat are you wanting to know it is pretty simple wiring if you are doing something custom the black/white coming out of the cdi is the kill wire for ignition the yellow out of the stator is you lighting coil which will run your lights and the regulator blue wire needs to be connected inline to regulate voltage cdi hooks up color match to stator wires orange goes to coil out of cdi black out of cdi should be grounded to coil and frame white out of stator is hand warmers and red/white is charge for battery if electric start equipped
faithfullyamaha
- Oct 31, 2014
- minnesota
- 09 phazer rtx
Weird something isn't quite right. I have on my cdi red, brown, orange, red white, black yellow, and black
Stator is white, brown, red, yellow, white red, black
Should I go rd/white to rd/white
red to red
brn to brn
black to black
That leaves white and yellow open?
All I need wired is the ignition.
red to red
brn to brn
black to black
Yamaha Nutz
yes match color for color. Do you have a white plastic on the cdi that has black and black /yellow in it ? That would be the TORS and that will need to be bypassed by grounding the black/yellow with the black that has to be grounded to engine and chassis
