I have a 2012 Apex XTX. Last year towards the end of the season it started draining out the battery. Changed the battery and did the same. Checked the stator and wasn't to spec. so I installed a new one this season. Went for a ride and it's doing the same thing now. Draining the battery. Any thoughts where to look now?
Put a meter on the battery leads and start unplugging things until the draw stops. I would start with the voltage regulator as I have heard of them shorting and causing a draw when the sled/atv is not running.
George, Maim is right about setting up a meter and doing a draw test. If you find a large draw pull the EPS fuse first, think I remember seeing a post or two about the EPS modules having high parasitic draw.
