LABRADOR WARRIOR
- Jan 26, 2006
- Churchill Falls ,NL
- 2015 Viper MTX
My son wanted to take my sled for a ride today only to find out that no gauges,no head light,no tail light,?? replaced the fuse twice with two new ones just in case ,,still no go!!! checked wires everything seems ok?? It worked earlier today.
any suggestions?
any suggestions?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I assume this is on an RX1?
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
electrical issues
Sorry forgot to mention it's a 2004 RX Warrior
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Most likely a bad load control relay (main relay). It's located behind the RH knee panel and on the RX sleds I believe it's the right relay (left for the RS sleds). It powers the headlight and signal circuits.
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
electrical problems
That's one of those three relays just inside the buzzer?
I'll have to check tomorrow after work..Hopefully it's something so simple as that..not a wiring issue..and hopefully my dealer carries that relay
cheers
cheers
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Yes, they are next to the backup alarm. The part number for the main relay is: 8DM-81950-00-00. The left relay is for the carb heater, the center is the high/low beam control and the right relay is the main relay. The main and the carb heater relays are the same and you could try swapping them to confirm that you have a faulty relay. The high/low beam relay is controlled by the switch on the handlebars. It gets it's power feed for the bulbs from the main relay so if you don't have headlights it doesn't mean the high/low relay is bad. Start with the main relay first.
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
This is what just happened on my buddies 2004 RX-1 Traced it down to the main relay like grizztracks mentions. Problem solved!
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
problems
Thanks Guys
I'll try the relay replacement tomorrow..Suprised that my dealer has one in stock!
Thanks Guys
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
electrical problems
Thanks for you help guys,,replaced the relay and everythings up and running again..
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
electrical problems
Damn relay gone again!!!
What's causing this to blow..checked everything before could not see any damaged cables..
