engine code
mikeyrules
Earlton,Ontario
Canada
Rs Venture Gt
Hey guys,lets see if you can help me here,was riding today,all was fine till i stopped and chatted with a friend,when i went to start it again it gave me a code 11 and the little engine blinking .It wouldnt start.waited at least an hour,and it fired back up again.My guess is poor connection to the batterie,havent had time to look it up.
If someone knows what code eleven is i wont tear her down.
how many km on it. I would throw a guess at one of the grounding blocks is a little curoded.
Intermitent electrical my favorite ,maybe not.
error codes
It has 9000 kms,i think its the starter....although i never checked the grounding to the block.But the starter is very hard to turn by hand.
starter
Turned out it was the starter,the armature (bronze that touches the brushes) came apart and chewed the brushes,so i got another starter,still wouldn,t turn over,the starter relay burnt from trying over and over while testing...
Anyways everything works fine now,although i swore a bit puttin the airbox back in its right place.
