spray25
Rx1M5 said:Don't like to bud in on somebodys thread but I was wondering on the RX is the TORS bypassed by connecting the 2 wires on the right hand end of the carb rack same as my SRX was. I'm new to the rx.
Yep
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
YES
treewhacker
Do yourself a favor.....Unplug the tors and plug it into itself to bypass, the tors is a built in factory bug that needs to go away. It's the 2 pin plug on the R side on top/back side of carbs if I remember right.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
spray25 said:I would recomend you fix his before installing your SC. It would suck to have the SC magnify this problem to the point of engine failure.
Ray, I read this a little too late. I allready have the SC installed and am going to run it this afternoon here at the house. I have an wideband A/F Guage and O2 sensor so I should be fine as long as I'm between 12 and 14. I am running it in the low boost pully configuration with 91 prem. plus a gallon of 100 LL for insurance pruposes. I'll let you all know if there's still a miss.
Jim
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
The miss is gone
But I'm running a little lean at 3117" elevation. (17-18 at idle). I don't know if this is due to the red springs or not. MPI recommends the stock ones (can't find them ordered new ones). I'll see if the stiffer springs change this at idle. If not I'll adjust the air screws. I ran the sled with the choke on 1/4 to bring the A/F ratio to the fat side. of Stoich at idle and gave 'er hell. I'll also have to see how much the elevation change to where I normally ride effects the A/F ratio. I normally ride at 6500-10,000+ elevations.
Jim.
Jim.
spray25
Take out the red springs and go with the stock ones. The red ones will give you fits.
At idle it takes a LONG time for the A/F gauge to work right. Even if it is heated. Mine typically will not read right unless I take it for a quick spin first.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
spray25 said:Take out the red springs and go with the stock ones. The red ones will give you fits.
I did take it for a "quick spin"
Here's my pic taken during Idle this is with the choke at 1/4". As you can see the O2 should have been plenty warm (water temp 146.3 F). Oh by the way did I mention Boosted
?Jim
