Sno Jet 70 SS
- Nov 13, 2005
- Eagan, MN and Ironwood, MI
- www.johndee.com
Does anyone know what size allen wrench the engine oil drain plug is on an 03 rx1?
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
05 is 6mm 03 should be the same.5mm to remove the access cover.
Sno Jet 70 SS
- Nov 13, 2005
- www.johndee.com
I got it done. I can't believe how much that time that oil filter took to change.
filter
It is a little biy of a pain in the a$$ to get the battery cage out. But once it is removed at least there is all kinds of room to get to the oil filter.
RX-1 Flyer
Yeah no kidding Sno Jet. Congrats on the initiation!
NB-NYTRO
I couldn't beleive the time it took on my Apex... look at the bright side.. You saved yourself some coin doing it yourself and you are your machine got better acquainted.
