Wire into the yellow/black wire coming out of the CDI box. This will work.
Also, depending on which racepak you are using, it might need to be reprogrammed to go over 10,000 rpm's (my Hot Tach Pro did).
The wire at the cdi should be the same signal at guage, not sure if it is square wave , my sleds not together so I can't test. Find someone with graphing meter or lab scope if you can,t get it to work.
