You should be able to idle up to fan operation temp.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hey TD thanks would you happen to know at what temp the fan would turn on?You should be able to idle up to fan operation temp.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
i'll go and let it idle in driveway to that temp to see this would be a simple way to make sure it's working!!Hey TD thanks would you happen to know at what temp the fan would turn on?
Crazy Canuk
yamamarc, my fan turns on right around 93 and will keep the sled in the 90-93 range. You can definitely just let it idle up to there.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
perfect thank you sir!!!! I will idle it and see if it starts upyamamarc, my fan turns on right around 93 and will keep the sled in the 90-93 range. You can definitely just let it idle up to there.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Out right now and it's staying at 73 c even on roads!!! I removed the mesh guard wondering if that's what did it (fixed it)
Anyway the "fun flipper " is going to get me in trouble
Happy my exhaust is qweit because the trail never looked twice but stared at wife with sandales exhaust
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Mine runs at anywhere between 70-80 C in fresh snow or rock hard ice. I put on 400km yesterday on the trails and never saw over 80.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hit 104 c for temp on road coming home.....
I know 100% that my rad fan isn't working now. My wife's fan was running when we got home and her temps were in the low90s. I shut off both machines and her continued to run for about 20 second and mine wasn't
I turned the key on hers and fan started
Put my key in the on position and nothing
didn't run and I was showing 101
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
So it's one of 3 things
Fan itself
Relay
Or the extention cable that came with the MPI kit that plugs into thermostat house..
Anyone know of the easiest way to test
For the fan itself I will run 2 wires directly from battery
Relay I'll test / or replace
As for extension I will check resistance
If anyone has simpler methods to check please chime in
Fan itself
Relay
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I will post a new thread to see if anyone has any tips on troubleshooting
