apexltxgt11
I just picked up a vintage ride. Cleaned the carbs and serviced the unit. It seemed to run really well off the start(first 2 days); however now once it warms up it bogs and will hardly pull itself. I can remove the mag side spark plug cap with no change to the way it runs, however if I remove the PTO side it dies. I am suspecting a mag side crank seal; however wanted to ask if I was going down the right road with my train of thought.
The unit has plenty of spark, and new plugs do not help the one cylinder running symptom.
striker606
- Feb 11, 2014
- Maplewood MN
- 2009 yamaha nytro xtx
Have you done a compression test on that cylinder?
apexltxgt11
yes 100 psi in both.
striker606
- Feb 11, 2014
- Maplewood MN
K I don't know much about the older sleds but maybe you have a problem with an adjustment on your mag side carb. How do the plugs look? Is the one thats not firing wet? Or lean looking?
apexltxgt11
It's a single carb. It does appear wet. If I swap the plug and cap between cylinders the pto side runs. I'm ruling out fuel issue or electrical I think
Sent from my SM-G920W8 using Tapatalk
nbsledder
Coil or weak stator.
apexltxgt11
Coil is new. Unsure about condition of the stator
Have you posted and registered on Totallyamaha.net forums?
apexltxgt11
No
Way more Vintage guys over on that side of TY.
apexltxgt11
Pulled the recoil off. Found its oily behind the flywheel. Crank seal it is
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
That is exactly what I had happen on the 340 I own. Man those sleds were simple ran good and so dam reliable!
yup they where reliable. could be a spark plug cap as well. they some times go out of spec.
