EPS light on
slimjim2525
Windsor Locks, CT
So I found my POD was bad per a previous post, and changed it. The lights that were on are now off, but still have the EPS light on. Can't really tell if the power steering is working or not. Any ideas?
on with just the key on or on when the sled is running?
you should be able to tell if you put the skis on a rug and try turning thr skis then turn on the key and turn the skis that is haw they demonstrated it at the shows.
The light is on with just the key on and running. We'll try to put on a rug and see if that can make a difference for me. It's a little hard to tell at this point.
Check the all plugs to the power steering controller in the nose area. Could be unplugged. I needed to zip tie mine as it kept coming unplugged
Well all I had to do was move the sled. Moved it out of the garage to put it back in the trailer and the light went out. Weird?
yes may have had a code and it was waiting to be sure it was working properly and reset itself.
