JUST WONDERING IF THERE IS A TRICK TO ADJUSTING THE REAR SHOCK ON A 06 ER WITH THE ADJUSTMENT ON THE TUNNEL(CABLE IS BROKE),SOME PEOPLE SAY IF YOU REPLACE THE CABLE IT WILL BREAK AGAIN
SharkAttak
noahster said:JUST WONDERING IF THERE IS A TRICK TO ADJUSTING THE REAR SHOCK ON A 06 ER WITH THE ADJUSTMENT ON THE TUNNEL(CABLE IS BROKE),SOME PEOPLE SAY IF YOU REPLACE THE CABLE IT WILL BREAK AGAIN
mine broke to, i'm not fixing it
redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
Mine has broken twice in the past. The newest cable is pretty durable - Yamaha made it stronger in 2008 - been on mine for the past three seasons and is still intact. Of course, this new cable costs twice as much too. I think it was $97 when I bought it back in '07. Not totally sure though.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I have a brand new cable in the baggy still if anyone wants to buy it....I can put it in the mail easily!!
I put in an Ohlins this season, works great!
with the cable broke can you adjust the shock at the top of the shock by hand or with a tool????????????
87gtNOS
- Nov 30, 2005
- Toronto
noahster said:with the cable broke can you adjust the shock at the top of the shock by hand or with a tool????????????
I suspect you would still have the cable inerds....so use it and adjust away!
zeke
cable
i use a green robertson (square) screw driver that i cut the handle a little shorter. it fits perfect and if you take out the three screws and remove the side adjustment knob you can look through the tunnel with the back end jacked up and see what you are doing.
yamahahaapex
I replaced mine last year with the "updated" cable and never adjusted it since summer. Looked down closely at it yesterday only to find its broke. I wont be replacing it either. Garbage!
MikeAttakNYC
Fox MEGA. Bye bye cable bulls**t
