sxrviper
My 08 nytro has been flawless till this year,i keep getting code 13 and also 84.I cleaned airbox,blew out sensor lines,cleaned throttle bodies,new throttle cable,plugs ,oil change.I can ride for about 30 mins and then sled starts getin code 13 and stalling eveytime i slow down.Tonight i got code 84 as well as 13 and sled still stalls when slowing down.Im goin riding all weekend and the way it's running will be no good.Possible crank sensor maybe or am i out of adjustment somewhere,my buddy's nytro was code 84 and we adjusted cable and it runs good...what am i mimssing here ... thxs
It means the hose either came off or is plugged on the sensor that is attached to the airbox. Or sensor is bad
sxrviper
The hose is attached to throttle body and i blew it out and it is connected,so i guess i need a sensor.
sxrviper
Is there any chance that a weak battery might cause this as well,i cant find anything wrong with hoses and sensors test ok.My battery in diagnostic mode only shows 11.6v so maybe this is my issue...thxs..
