chris2011
- Jan 19, 2016
- michigan
- 2011 Yamaha nytro xtx
I have a 2011 nytro and I am have a engine code of 84 tors at first I was thinking that it was the speed sensor I changed it and code still there also adjusted the throttle cable according to the owners manual and code still there.. long story short I am at a loss any ideas any help would be great
Thanks Chris
Thanks Chris
Mark Thayer
- Jan 17, 2016
- MN
- 08 Nytro
Chris
Search this site for your problem, I had the same situation and noticed that the cable had detached from the metal 90 degree bend. Had to replace the cable. Also disconnected the TORS and installed a tether with rollover kit. Lots of good information here and also with the people they recommend.
Nytro94
- Dec 6, 2015
- New york
- 08 Yamaha Nytro RTX
Tors... it is a beach buddy.... I broke mine you need to buy a new cable and rewire the cable under if you did any steering post mods... I wired mine on the back side of the handle bars.
chris2011
- Jan 19, 2016
- michigan
Thanks yeah I worked on it last night and turned out that the throttle body's were dirty and wasn't closing all the way after cleaning and removed the 84 code sled isn't throwing it anymore I messed with the throttle a bunch of times opening and closing slow and letting it closing it fast and seems to be working now this weekend will tell... thanks for the advice nytro 94 if this doesn't work then I will try that
Thanks Chris
