zigzag420
So a few times riding my attak when im carving in the powder and if i happen to fall off the sled will go on a few feet and every so often it will shut off and give me error code 30 which is low oil pressure. is this normal if it does that, im thinking it is cuz when carving all the oil is to the one side of the motor. the sled will only do that if i fall off tho and not that often. would apreciate advise from you guys the experts.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
When you fall off how far over is the sled tilted? My guess is that you might have lost a bit in the air box through the oil breather tube. Check the oil level and top off if needed.
zigzag420
probably tip it on its side by a 45 degree angle maybe a bit further over when carving i checked the oil this morning before starting the tour and it was perfect and i did check the airbox after riding and there was no oil in the air box but i didnt check underneath the foam part.
snife
code 30
My apex mountain was doing the same thing on Saturday....my oil level was 200-300 ml low. after it as topped up it was fine
