error code#30
mikeh
I have a 2016 vector I was having trouble with it showing a #85 error code , I traced the wire from oil pressure sensor to a connection on the left side of engine just under air cleaner box along the frame . took connector apart sprayed electric cleaner in connector fixed problem. now I have a code #30 that comes on and shuts motor off . you can restart it run a little while then it shuts off again. I am thinking the sending unit for oil pressure is bad. anyone else have this problem.?????
