Jeff33
- Feb 28, 2015
- 2009 Yamaha nytro
i replaced the oil pressure switch with no luck,sled starts but then shuts off and flashes engine code 30,oil level is fine. Any ideas?
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
Im no expert here, but maybe no oil pressure? Bad pump or sump?
tangerine427
- Dec 28, 2010
- Palo, IA
- Nytro XTX
I've run into this before with a couple nytros. As long as it hasn't been run dry of oil or has 20,000 miles on it. Check your screen on the bottom of your oil tank. You have to drain oil out of it and pull 2 5mm bolts out and the screen comes out the bottom. If it's got crud on it clean off with brake cleaner and reinstall. If doesn't fix it time for rebuild.
