frano
I have 6 excell wheels on order for my 2010 Vector GT. Can they be changed with the skid in place and how big a job? Thanks.
If they are the small idler ones yes you can. Get the back end picked up or use your sled lift.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yes you can. Worst case you might need to loosen the track tension. Otherwise should be a piece of cake. G.B.
topdawg1817
You will be just fine replacing without having to remove the skid. Just have to jack up the back end. Should not take long after that, then enjoy the longer life from your hyfax.
