torszula
Just installed new hyfax on 08 Nytro and have about 200 miles on them so far this year and they are already gone! They seem to be pretty good up by the front idler wheel but nothing in the back. Never owned a Nytro before this season so not sure what the wear is like on these sleds but this seems excessive. All parts are on skid and all the wheels are brand new.
Super Sled
- Feb 25, 2009
- Summit X
Try adding scratchers to get lube up the sliders. It really helps.
dab102999
How loose r u runnin the track...i have always run loose enough to ratchet and the snug a turn or two.
207nytro
most importantly trail conditions? what have you been riding in? how loose is the snow? if your running on what is basically ice your slides won't get lubricated or cooled.
scratchers will help a ton for hard pack and ifi were you i would look at a ski mounted option due to the short track of the nytro. if you mount on the rails most of the snow or ice sprayed will not flow into the tunnel or rear suspension area.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Super Sled said:Try adding scratchers to get lube up the sliders. It really helps.
X2 I can run over 4000 miles before needing new ones.
09nytro
Add wheels on outside of rail in back . I put Polaris wheels with Polaris blocks , no more wear or you can put the excel wheel kit on it
