Richnytro12
anyone have any problems with bolts coming loose?
i installed a full hindle exhaust last year and now i noticed that i'm missing one bolt. all the others are good and tight. what is the bolt type and can i just get one from the hardware store or are they a self locking flange style?
thanks!
Rich
thanks!
Rich
Dr. FeeLGooD
Loctite required. Its a metric flange style 6mm I think. Take another one out and compare it at the store. Site rules require your location posted in your profile. Welcome to the site. The search feature here is your friend.
Richnytro12
Thanks!
Mountaintech
It is an 8mm bolt with a small flange head. 10mm wrench will fit.
Richnytro12
a regular ZINC coated bolt then and some BLUE loctite and i should be good?It is an 8mm bolt with a small flange head. 10mm wrench will fit.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Wont the heat weaken the Loctite over time and render it useless?
MS
MS
Dr. FeeLGooD
Mine havent fell out. All I can say for sure. I loctite everything.
