Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
I saw that as well but maybe a fluid transfer flex could work for exhaust. Call them a see what they say.
BurrFabrication
- Dec 12, 2012
- Armstrong BC
- www.burrfabrication.com
Vibrant performance builds the little flexes... But just weld it solid
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
The Nytro flex pipes are smaller.
henks
- Dec 29, 2013
- East Central MN
- 2008 Phazer
In diameter or length?canoehead said:The Nytro flex pipes are smaller.
henks
- Dec 29, 2013
- East Central MN
- 2008 Phazer
Does anyone have pics of their sled with the nytro joints intstalled. Curious as to how they fit in.
*Edit*
Nevermind. I was zoomed in too far on the parts fiche.
*Edit*
canoehead
- Jan 14, 2011
- NE, Alberta
They are bigger in OD than the Nytro.
henks
- Dec 29, 2013
- East Central MN
- 2008 Phazer
So the nytro piece would not be a direct bolt/weld on then?
henks
- Dec 29, 2013
- East Central MN
- 2008 Phazer
To get by I just bought some of the cheap flex pipe from a local parts store. Lasted about 150 miles before one side broke on Saturday. I still had a leftover chunk so I fixed that. I'm going to try to just ride it out until the season is over (work and school are going to start taking a lot of my time real quick).
I have a buddy that works at a machine shop and he said he would weld a couple of these in for me.
http://www.summitracing.com/parts/vpe-62308/overview/
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
I have the same problem as henks, have you come up with a long term repair?
Smokyred
henks said:To get by I just bought some of the cheap flex pipe from a local parts store. Lasted about 150 miles before one side broke on Saturday. I still had a leftover chunk so I fixed that. I'm going to try to just ride it out until the season is over (work and school are going to start taking a lot of my time real quick).
That looks like your best bet short of picking up a used exhaust off of eBay...
Dave
henks
- Dec 29, 2013
- East Central MN
- 2008 Phazer
To get me through the rest of the season I just bought some of that cheap exhaust flex pipe you can get at your local auto parts store. One cracked on me again, so I put in another piece. This summer I'm going to have a friend weld in two of those braided exhaust flex joints that I linked to in an earlier post.benjamingvsu said:I have the same problem as henks, have you come up with a long term repair?
Aj fire
- Oct 26, 2018
- Nf
- Nytro
So I did a bunch of searching online, and stopped in quite a few parts stores around...and I can't find any place that has those flex joints small enough. Most car/truck parts stores can only go 1 7/8" diameter, some 1 3/4". Online I can only find a place that has them at 1 1/2", which is still too big.
So, anyone have any other ideas (other than buying a whole new exhaust)
Aj fire
- Oct 26, 2018
- Nf
- Nytro
*Edit*
I just completed install of 3 stainless flex pipes on 09 nytro, tough install but they work great. Bought at Toronto sled show $50 each
