exhaust
You do not need to take your handlebars off unless you want to remove tank cover. Just disconnect ignition switch and spin tank cover 180 degrees, remove tank and heat shield and wonder how the hell they got that motor in that small space. Good luck. Oh ya, my heat shield under tunnel was the problem. I used Yama Bond #6 and that worked for two years, then I removed the shield when I put the turbo on. I used Yama Bond for my rattling screens too.
MM
