extending 07 RTX to 136"
apexrtx10
Tribes Hill NY
I'm planning on extending my 07 RTX to 136" I have the rear heat exchanger on the sled, do I need to put the stock tube back in or will it be fine with heat echanger and some sort of protector?
144" with a setback skid.
Apex06 have you ever run studs with this set up. I will be running them and just wondered if that woud make a difference. That exchanger doesn't hang down that far could possibly fab a protector for it.
I extended mine to a 136 and originally left the coolant tube in the original location. I ran 1.45 studs and they hit the tube in several places alomost going right through the tubes, if that had happened it would have killed the motor. I moved the tube back to the rear of the extention usuins 2 1 inch pieces of aluminium tube. I had no issues at all and it was a great improvement over the 121.
