I use a cheapee dent puller and use a 3 inch coarse thread sheet rock screw. I screw it in an inch at a downward angle. The hyfax pulls out in less than a minute.
What helps is I drill a couple little holes in the end of the new hyfax before I install. Without drilling the pilot holes before you install, the beveled edge can be a pain in the arse.
The holes make starting the screw a breeze
