apexg88
I bought an 06 ER at the beginning of February and absolutely love it.. put 2500 stress free miles on it in northern maine but last weekend I raced an F7 and was expecting to blow him out of the water, he got a 2 sled jump on me than I caught up mid range, but we were dead even ski to ski when the dream o meter read 115. This made me mad.
My sled is stock I want to modify it in the off season
What mods have you found to really work
Whose Clutch kit?
What gearing?
And anything else?
I NEVER want to see an F7 next to me EVER again
Whose Clutch kit?
What gearing?
And anything else?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
F7's are fast animals, don't feel bad.
berge75
F7's are no slouch. Start with clutching,cr10ek plugs and air box.
yamaouch08
good luck against a well tuned F7!
Turk
Tech Advisor
X2...a well tuned f-7 will/should kill an apex. Pick on the lame ducks that have clueless owners.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Take your pick of either a turbo or supercharger.........
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Turk said:X2...a well tuned f-7 will/should kill an apex. Pick on the lame ducks that have clueless owners.
Even the well tuned F7's I have seen are tough to the century mark, maybe a bit over...... I believe the Apex/Attak should out run them on top if setup properly. I have a buddy that owns a 2007 Attak that is bone stock and every time I have been around him that thing wings up to the 120 mark and beyond on the dream-o-meter. It is flat out FAST.
SledFreak
- Feb 7, 2005
- Ontario. Canada
The only ones that are real strong are the 03's. I have beaten alot of them, but yes, you won't do it stock forum. Also you need to hook it up. Start with 1.450 studs. 23/38 gearing. Lighten up the inner rivits and center rivits in the Primary weights from 4.6g to 3.6g and leave the tips alone. Make sure the track is up to spec. That should take care of it.
If you lose again, then run install a PCIII/ignition controller and put on a Fix air lid. The key is to getting it hooked up. The Apex is very slow in soft snow, but on hardpack it fly's. That's why you need to run the 144 1.450 Woody's meg studs. Not much money in the gearing, studs and adjustments to the clutch weights. Good luck...
Shivesy
My son & I raced a few times this year. He was on my wifes 06 Apex ER and I was on the 07 Attak GT. He jumped out in front instantly to a 3 sled spread 3 times in a row. I could stay with him but could never gain on him. We weight the same and all is stock for both machines except for the Apex. The Apex has Ulmer clutching.
yamaouch08
What's this have to do with racing an F7?Shivesy said:My son & I raced a few times this year. He was on my wifes 06 Apex ER and I was on the 07 Attak GT. He jumped out in front instantly to a 3 sled spread 3 times in a row. I could stay with him but could never gain on him. We weight the same and all is stock for both machines except for the Apex. The Apex has Ulmer clutching.
jlemieu1
- Feb 7, 2005
- Rosemount, MN
- 14 Viper LTX SE, 14 Viper LTX
I got smoked by a 03 F7 on a long lake run. I was running dooly carbides with stock skis.
This year I barely bet him with Curve skis, Shaper carbies and CR10EK plugs. 105 on GPS (127 on dreamometer). Honestly I think his kitty is starting to hit on old age.
snerkman
yamaouch08 said:What's this have to do with racing an F7?Shivesy said:My son & I raced a few times this year. He was on my wifes 06 Apex ER and I was on the 07 Attak GT. He jumped out in front instantly to a 3 sled spread 3 times in a row. I could stay with him but could never gain on him. We weight the same and all is stock for both machines except for the Apex. The Apex has Ulmer clutching.
The op asked what mods work. He is offering his experience with the Ulmer clutching vs stock.
Shivesy
[/quote]What's this have to do with racing an F7?[/quote]
If I'm not mistaken apexg88 lost the start of the race with an F7 by 2 sled lengths. My message was that he should be able to pick those 2 sled lengths up easily with a clutch kit.
jwifferdill
jlemieu1 said:I got smoked by a 03 F7 on a long lake run. I was running dooly carbides with stock skis.
127 on the dreamola was only 105 GPS? That's scary to think how far off these speedometers are.
I too have come across some pretty strong F7s, all of which I found were 2003s but I've seen a few slouches as well. I'll still take my stock Apex and ride all day without having to worry about whether or not I'll need to be towed home.
apexg88
Speaking of towing I towed that F7 in the following day, that made me feel a little better
