Yamaha Announces Major Options for 2011 Nytro MTX
Yamaha-exclusive 180-hp Push Turbo, MPI Supercharger systems
Yamaha announced at a press conference today at Hay Days exclusive power options for 2011 Yamaha Nytro MTX models.
A Push Turbo and MPI Supercharger system will be available through Yamaha dealers later this fall. Both systems will produce 180 horsepower and feature factory presets that eliminate user tuning.
Both the Push Turbo system and MPI Supercharger system are designed for 6,000-ft and higher elevation applications.
Both systems are priced at under $4,000 USD.
Yamaha also announced an optional rear suspension kit for the Nytro MTX that reduces the weight by approx. 25 pounds.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
Distributed exclusively by Yamaha Genuine Parts & Accessories
MSRP: $3,995
YPAD Part Number: SMA-TURBO-00-00
Fits 2008-2011 FX Nytro MTX Models
Easy installation, only cutting required is a 2-1/4 in hole for charge tube. Turbo comes pre-assembled and mounts above tunnel in place of factory exhaust muffler.
Uses OEM style wiring connectors
180 HP on premium pump gas
8 psi boost (non-adjustable)
1-year warranty (through Push Turbo)
Available exclusively at Yamaha dealerships
For use above 6,000 ft elevation
"The Push Turbo kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
FX Nytro MTX Supercharger
by Mountain Performance Inc.
MSRP: $3,995
YPAD Part Number: SMA-SUPER-00-00
Fits 2008-2011 FX Nytro MTX models
Uses OEM Style wiring connectors
Uses stock exhaust
6 psi boost (non adjustable)
Features fuel-only GEMS control module that is non-adjustable
1-year warranty (through MPI)
"The MPI Supercharger kit is designed only for operation at elevations above 6000 feet. While installation of this kit will not 'void' your snowmobile's warranty, specific failures determined by Yamaha to have resulted from installation of kit components or other modifications may not be covered by the Yamaha limited warranty or extended service coverage." -Official release statement.
More to come...
UPDATE
Here's the details:
FX Nytro MTX Turbo
By Push Turbo
MSRP: $3,995
MSRP: $3,995
Uses stock exhaust
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
WOW I'd say that is a step in the right direction. I'm guessing a lot of the turbo guys on here will still opt for the bigger power stuff out there but this may appeal to the less mechanically inclined who don't want to tinker. I wonder how much install cost ya over the 4g for the turbo?
Why can't they make it for every Nytro, why only the mountain guys?
**sj**
Ive been speaking to Mac at Mountain performance for years on His kit and the relationship with Yam....congrats to him...he has invested a tremendous amount of money and patience to here..
this will appeal to the masses who want to turn to the dealer for a turn key setup..and will keep dealers in business with the lower volume sales we are seeing now...
eventually ..flatlanders will see some version...
doo_man
shaddow44 said:Why can't they make it for every Nytro, why only the mountain guys?
Buy a MCX180.....works great in the prairies and mountains!
fxnytroxtx
Guest
Will MCX 180 work good at sea level up to 3000 ft?
bwwelke
Would it work on a XTX?
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
it will.
MCX will work just as good at sealevel as i does at any altitude. They have a altitude compensation boost system.
Alatalo
From the pdf file about the MCX 180 hp kit:
"...we intended to make this kit really simple without any boost compensation for altitude. But at 2000 meter altitude (6500 feet) the power drops from 180 hp to just above 140 hp and at 3000 meter (10000 feet) the power is down to 125 hp. A stock machine is down below 90 hp at this altitude. After some tests we decided to install our altitude boost compensation even on this kit. Now the power is 180 hp at any altitude..."
This pdf can be downloaded from MCX website.
http://www.mc-xpress.com/
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Mcxpress is the way to go!!
The best turbokit ever!!
180 hp/ 240 and 270 in any altitude on pump gas!
fxnytroxtx
Guest
Sweet i want one. MCX180
The yamaha rep at Haydays was telling us it's approx 7-8 hours install time for the super charger and less for the turbo. So factor in your shop rates if you want the dealer to put it in for the extra cost.
sleddingfarmer
I still think I would get ulmers kit. Last I heard he was going to make some sort of switch to lower the boost to run 87 octane if necessary. Thats a big bonus for me.
