Fault code 46
Roger
Osgoode Ontario Canada
Canada
2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Hi Folks.
Where would I find the list of fault codes. As my '07 Venture's newest problem is that it won't stay running and is flashing "engine" and "46"
Thanks Roz
This makes sense, as the battery is dead and it has to be boosted to start. I guess a low battery can't keep the electronics working properly to keep the engine running.
Roz, where can we find this list of yours.
Roger
Ran across it almost three years ago at snowmobileforum.com/yamaha-snowmobiles/14613-yamaha-trouble-code-list hope it is still there for you
Thanks Roz
The battery was dead. With a good battery, it stays running.
The link didn't work. I'll try different variations of your link. Would you have a different link?
Roger
The list I downloaded included
15-Throttle Position Sensor and Circuit problem
16-Throttle Position Sensor stuck
21-Coolant Temperature Sensor and Circuit
42-Speed Sensor
46-Power Source Voltage
80-Grip Warmer Switch and Circuit
81-Grip Warmer and Circuit
82-Thumb Warmer Switch and Circuit
83-Thumb Warmer and Circuit
84 TORS System Activated(throttle override)
86-Cold Engine Protection Activated
There may be more but thats all I have
Hope it helps
Thanks a lot Roz.
I'm printing off your list, and keeping it on the sled.
Roger
