Four Bitten
I just finished installing rear heat exchanger on my 07 attack . Everything went well. I was wondering if you guy"s can give me some tips on filling and bleeding the system, any help would be appreciated.Thanks
ROCKRTX
You should mix your coolant 60/40,and you got a bleeder bolt on the rear tube or rad of the sled but you have to remove the rear plastic part that cover it to see the bleeder bolt.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Make sure you use Yamaha recommended coolant otherwise you'll wast your waterpump seal..
ualav8
BADSLED said:Make sure you use Yamaha recommended coolant otherwise you'll wast your waterpump seal..
really?? this is the first i've heard of that. what brand does yamaha recommend?
BADSLED
- May 13, 2004
- Syracuse, NY
Well, let me just tell you I've replaced the coolant with automotive coolant premixed and after several hundred miles tiny black chunks of rubbered appeared to settling on bottom of my coolant tank. Lookin the service manual and it only recommends Yamaha coolant. Just trying to be proactive and save you from a possible headache.....
