Finding fault codes
Mercer5
Wales WI
2014 Viper, 2001 SRX, 1990 Sno Scoot, Kitty Cat
I found out how to get diagnosis started on gauge, BUUUUT can I get it to show what codes have come up prior? I started looking through all the threads and got dizzy !!
My 06 RTX woudl go into limp mode when running, at first th temp light came on with check engine light so thats what I am chasing first, I did the coolant thing already.
Ideas??
Jim
when you are in diagnostic mode scroll up or down thru the diagnostic code numbers displayed on the guage. The history is code#61
00 will display if there is no stored codes.
If multiple malfunctions are recorded different codes will be displayed at 2 second intervals and repeat over and over.
there is a thread with aq link in the apex forum to download the service/repair manual. find it and download it. it will help you out big time!!
Thats exactly what I was looking for, here is what I found.
11,22,81, 84
84 is the TORS and thats the only one that UNABLES the sled which is what it did, shoudl I just disconnect like I have on all my other Yammy's?
i would try clearing out the codes and starting over again.
you can disconnect the tors but if it was me i would want to be sure the tors was actually a problem. i would want to see it screw up a few times before just disconnecting it.
How do I clear the codes?
do you have a manual? if you don't you need to get one.
it is clearly explained in the manual on page 600.
you can download it from this site if you do a search.
diagnostic code 62 clears the codes
• Erases only the history codes when the engine stop switch is turned from OFF to ON.
If the engine stop switch is ON, turn it
OFF once, and then turn it back ON.
I had some problems getting my codes to clear when i did this. just keep trying what is posted above till they disappear
I have the manual but there is no page 600, it only goes to 486.
Covers Apex/Attack 2006 - 2008
Can't fidn it
I am looking at the supplemantary service manual
lit-12618-02-44
8fs-28197-10
do you have that one??
When you open the manual adobe reader should read pages 1-683.
Page 600 on adobe is page 71 on my manual. Under fuel injection system.
Found it, thanks, It worked and all codes have bene cleared. SO do you think I will have troubles again with the TORS? Or is thsi one of those pesty problems, now that I know how to clear codes I can do that on the trail, or shoudl I replace/and or disconnect TORS?
