local 25
Kren
Local - looks good. On another note, were you able to put your handguards on without any issues. I want to put some on but it seems like many (for instance the kind that go on the Rev) wont fit due the handlebar setup on the RX. If you had no issues, what did kind did you use?
local 25
they went on very easy,the left one (brake side) i had to clip a little piece of platic of the housing to get it to sit flush.took 2 seconds to clip it off with a pair of dykes.the ones i bought are the sport tech and they dont hit my windsheild at all.if you want ill post a pic(now that i know how) of the area that you need to clip. Mark
I would say adding pics...LOL
local 25
yes Mr Sled, you are right..... after all that aggravation ,it was what you had said on the other fourum about the picture size.it needs to be 680x460 .the reason i was able to post the pics of my beach camper was that i had swithed the camera to high resolution 1200x1600 when i took the pics of my RX-1 ....live and learn. anyways thanks for your help(again)
No problem.....just glad you can share the pics with us and the M10 install looks great
Kren
local, show some pics of the handguards if you dont mind...thanks.
local 25
hand guard pics for KREN
there was a piece of plastic that was attached behind the wires coming out of the swith assembly (you can see where the cable wrap had made indentations)clip off the cable wrap and then clip of the little piece behind it and the aluminum bracket will slide right up flush to the switch assembly
