tylerearl88
Started my diy turbo 08 nytro tonight and have some questions. When I start it up and at idle it is clean and free of smoke but when I give it throttle Smoke pours out the exhaust. Oil is also spitting out. How much oil pressure is coming from the motor? ( I am t'd in at the sensor). I had a facet pump hooked up but it really didn't seam to do much acted more like a restriction. Should the pressure coming from the motor to the turbo be restricted? I took the line off the turbo and it is pumping a ton of oil.
And just a side question. Does it matter witch way the oil lines go into the turbo delivery and return? Its just that the way I have the turbo mounted the original drain is on the top and the original intake side is on the bottom.
Does the way the side the oil is delivered to the turbo have anything to do with the ease of rotation of the wheels?
Thanks. I am using a 16t Mitsubishi turbo.[/i]
