Al Bundy
Hi all new member from Maine. Just bought 04 Warrior and made the haul to Madawaska ME for 1st ride. Trails from Madawaska to Caribou were great. 7:30 am and -9°f. and the trails are freshly groomed and uncrowded. I really like the sled. I read a lot about it, good and bad, before purchasing. I will put new bushings to tighten front and new carbides or skis to prevent darting. I will also be putting in m10 or m20 skid. There was only about 20 miles of rough trail, but that was enough to know no-action isn't going to cut it. One question I have for you folks is what do you recommend to help with pushing in corners. I noticed I really had to keep on the throttle to prevent pushing. There's a little inside ski lift as a result, but that seems to put enough pressure on outside ski to limit push. Thanks
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Team Fast skids are great! I would highly recommend the M20 with an on-board compressor...you will thank yourself many times over!I will also be putting in m10 or m20 skid.
A 136" mono skid with custom calibrated shock would be another great option...more economical too! This is a nice upgrade that can easily be installed in a weekend, barring no other issues that may need addressed while you're in there.
Al Bundy
Thanks. Id like to say your rebuild thread was interesting to see and good pictures.
Redbeard
- Oct 14, 2011
- IN
If you opt for a 136" mono, contact Travis at Barn of Parts.
http://m.barnofparts.com/
Also, watch the forums because skids and other miscellaneous items randomly come up for sale by other TY members.
This is a great site with many good people! I've made some really good friends on here!
Indy
Snowtrax carbides will eliminate all darting and most of the push. I wish I had these many years ago.
Barn of parts sales them; http://m.barnofparts.com/
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
I think you mean SnoTrackers don't you?
Al Bundy
Yeah that's what parts dealer recommend. (Snow trackers)
Redbeard
- Oct 14, 2011
- IN
I'd disassemble your front end this summer and check for worn bushings, etc. Once greased and re-assembled, check your ski alignment. Different ski's, etc will not help if your front end needs serviced and/or your alignment is off!
Al Bundy
Yeah I already plan to do bushings and any tie rod ends that need replacing.I'd disassemble your front end this summer and check for worn bushings, etc. Once greased and re-assembled, check your ski alignment. Different ski's, etc will not help if your front end needs serviced and/or your alignment is off!
Al Bundy
al bundy i would reccomend a 12mm or 13mm swaybar if you can find one. really helps with the roll in the corners if it does not already have one.
Al Bundy
Redbeard
- Oct 14, 2011
- IN
Al, that would be a good buy if it included the mounting kit for your sled. You would need to buy a mounting kit specific to your sled, which would be about $200. Then, to get the most out of the M20, the shocks should also be calibrated to your sled and your body weight. That would be an additional $100+. That would put your investment up in the $1300 + range.
Right now, Fast has the M20 on special for $1600, which would include the proper mounting kit for your sled, plus it would be calibrated for you!
I could then show you where and how to get an air compressor purchased and mounted in your sled for about 1/3 the price!
Al Bundy
Thanks buddy, nice to have info from people who've done a suspension swap already. Ive been on the teamfast website a lot lately and noticed the sale. The $1600 is for 121 skid correct? Think its more $ for 136. I am in no rush to get a skid. I'll keep an eye on the eBay one and see if it sells, maybe make an offer.
In other news, taking one more and probably last trip north this weekend. Thinking Caribou, Madawaska and Fort Kent.
Redbeard
- Oct 14, 2011
- IN
Talk to Fast. The 136 may be $50-ish more.
