Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I was just looking at the Team Fast website and the price of their mount kits are $250, not $200 like I mentioned above.
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
Trails were great. Put on about 200 miles.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
For your push in the corners. The swaybar and other things mentioned helps a lot, but the also found we need to drive different than a 2-stroke. Takes some practice, but drive further into the corner and roll off the throttle right as you start to turn to set the outside ski, and then roll back on. You should find a very controlled turn as a result. Don't dump or whack the throttle as you will lose the balance needed. The inside ski will lift slightly and then use your outside foot (press down) to control how much and how sharp the turn. You will find that you use the brakes a lot less or even not at all.
Redbeard
- Oct 14, 2011
- IN
Nice sled, Al!
dexter
Hey Al... Nice sled. U buy it in southern Maine ? Looks like my old girl that I sold a couple years ago. Pm if u want maintaince history. I spared no coin on her. Did oil light bushings in the front arms.
Let me know
Let me know
dexter
Got to be her. See my powder coated arms and my custom wind deflectors
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
Yeah it probably is. The a arms are tight and have been serviced, maybe extra zerks? Also receipt from Ulmer for bushkit. It has a tank bag and what I assume is a block heater, and a near new track picked up the center. Previous owner(s) must have taken care cause shes in excellent condition. Factory cover is even good condition. Sled came with a repair manual in a binder with some printed off forum information from this site. Bought it near Windham. If it was yours thanks for taking care cause I've had a blast with it for the last two weeks!
dexter
Cool. That was a great sled. Have fun
4bangdan
- Sep 8, 2005
- Fort Kent, Maine
- 2004 yamaha rx1 2015 yamaha apex xtx
I second this all the way,great advice. Check out my avatar and signature or mod list. I wish you could try mine as is with the whole package. You would catch the mod bug bigtime.Al, that would be a good buy if it included the mounting kit for your sled. You would need to buy a mounting kit specific to your sled, which would be about $200. Then, to get the most out of the M20, the shocks should also be calibrated to your sled and your body weight. That would be an additional $100+. That would put your investment up in the $1300 + range.
Right now, Fast has the M20 on special for $1600, which would include the proper mounting kit for your sled, plus it would be calibrated for you!
I could then show you where and how to get an air compressor purchased and mounted in your sled for about 1/3 the price!
Al Bundy
- Mar 4, 2016
- Maine
- 2004 Rx Warrior
Are they done grooming? When I was up last weekend some trails had been groomed others not so much...I second this all the way,great advice. Check out my avatar and signature or mod list. I wish you could try mine as is with the whole package. You would catch the mod bug bigtime.
4bangdan
- Sep 8, 2005
- Fort Kent, Maine
This past weekend was perfect from debuli to caribou. All groomed as if it were febuary 1. You missed it. This weekend is shaping up to be nearly as good.Are they done grooming? When I was up last weekend some trails had been groomed others not so much...
