Dukester
RX1-snow: Clutch engagement is very close to stock and very smooth.
I am pulling about 6 lenghts by 60 mph and another 2-4 lenghts at 100mph.
My advice is to buy the kit from Matt and not fool around figureing it out. Spend that time riding. I feel it was money well spent. I am not a racer but I like to have all the performance I spent my money on with out loss of reliability.
Only you know if $400 is too much.
I hope this helps. Dan
welterracer
Very good info Sketr!!
snomonut
Dan-
Thanks so much for your comprehensive reply! If I could bother you, or anyone else who might have the answer, one more time. I'm like you. I prefer the softest ride possible and accept that to get that occasional bottoming of the suspension is fine. I'm confused by your application of the FRA. You say that you set it to the MAX, which is opposite to what I thought would provide the softer ride. Any further light you could shed here would be most appreciated!
Focker
This may sound stupid, but what is the FRA? I just installed a 136" kit along with a Ohlins rear main shock and I want to get an idea where I should start with setting this new system up?
- Sauk Prairie, WI
- www.ty4stroke.com
FRA= Full Rate Adjuster, It can be set stiff, mid and soft. If you look at the front of your rear shock, you will see a slotted bracket and a splined bolt that you just turn with a wrench. The top position is the firmist, and the bottom is the softest. Hope that helps...BBY
Focker
I thought thats what it might be but I wasn't sure... thanks!
Dukester
snomonut said:Dan-
Hi: You are right Max FRA is a stiffer ride than LOW FRA. The clicker shock adds an additional demension to the systems adjustability.
What I was tring to say is the the spring is used to carry the load (static load). The shock dampans the bump or change in load (dynamic load effect).
I set the FRA to maximum because that gives the longest travel for the rear shock for a given spring deflrction. I then use the clicker addjustment to control the damping effect of the shock. More dampaning relates to a stiffer ride. We start low with the clicker adjustment and go up to increase the size bump you can hit befor the suspension bottoms out.
If we didn't have a clicker rear shock we would only have the FRA adjustment to control the damping effect of the load, like the 03 RX1. The clicker shock is the big improvement on the 04 warrior.
I hope this helps.
Focker
Sketr,
Is that clicker shock like the Ohlins, where you just turn the little knob to adjust the shock? If so, then I should be able to try your initial setup and go from there.
Dukester
Focker; We put an Olins adjustable shock on a friends 03 RX1 and adjusted it the same way. The results were very good. What it does is let you pick your own dampaning rate so you can let the spring be just a spring to carry static loads.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Sketr2 How does the stock Warrior compare with your buddies sleds; the 800 Poo and Rev ( ride, speed, handling)? And are there sleds stock?
LazyBastard
BlueByYou2000 said:FRA= Full Rate Adjuster, It can be set stiff, mid and soft. If you look at the front of your rear shock, you will see a slotted bracket and a splined bolt that you just turn with a wrench. The top position is the firmist, and the bottom is the softest. Hope that helps...BBY
You've got that backwards. Bottom is the firmest.
Focker
So I should set my FRA to max, and the dampening to the softest...what about the spring tension on the main shock? Should I leave it where it is or adjust that too? I weigh about 180lbs.
LazyBastard
You adjust the spring tension such that when you sit on it, it sags just enough that the control rods are halfway between the space.
Dukester
Sketr2 said:Snomonut: This is how I adjust my suspension:
5) I set the rear suspension by lifting the rear of the sled to relieve the spring and set it down easy and measure the distance from the bumper to the floor. I sit on the machine in my normal riding position and I adjust the rear spring to give me a 2 inch decrease in this measurement. Before I get back on the sled again I lift the weight off the spring to off load the spring.
Now is the time to adjust the rear of skid frame. Note that the load carrying ability of the skid frame was set in steps four and five above. Ride the sled on a trail with bumps of the size you would like too ride over in a some what leisurely manner. Use the clicker adjuster to increase the dampening until you can ride over bumps of the size you think are reasonable. The key is reasonable and with in your speed range with minimal bottoming out. Remember the stiffer you make the clicker adjustment the less travel the suspension will have over a given bump size. Less travel relates to the stiffness of the ride. This adjustment controls the dampening effect in response to a bump.
I hope this helps.![]()
I hope ths helps you out.
Dan
Focker
Thanks alot guys, I appreciate the help. I just want to get my new longer skid to ride alot better than last years shorty!
