DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
I'm in the middle of adjusting the float bowls and now I think I did it wrong, I did a search and I've read threw the service manual but I still have my doubts, can someone give me an idea how it's done since I just flipped the carbs over and measured 11-15mm from where the bowl sits on the carbs to the top of the float
Kyle
Kyle
team ducktape
Some help here:DAGE said:I'm in the middle of adjusting the float bowls and now I think I did it wrong, I did a search and I've read threw the service manual but I still have my doubts, can someone give me an idea how it's done since I just flipped the carbs over and measured 11-15mm from where the bowl sits on the carbs to the top of the float
Kyle
http://www.totallyamaha.com/snowmobiles/aaTECH/floats_adjust/Carb_Float Adjustment.htm
DAGE
- Nov 8, 2005
- Other
- 06 Attak
alright I know I messed up the 2 I did, I just flipped the carbs over and measured 11-15mm's, so I guess I have to tilt the carbs until they barely touch the needle thing and then measure, this sounds like it's going to be a PITA
Len Todd
Just to throw a bit of humor at this, ... I never did figure out how to adjust the float bowls.
?? or How about, ...
When you have 4 of anything (e.g. carbs, wives, daughters, etc.), you got to have a lot of patience. ??
Now back to work.
Now back to work.
