polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I bought a used 05 RX1 in the spring last year. The owner had a CPR air filter and carbs jetted but removed the kits before he sold it. He lost a couple float bowl screws and rounded some others. I was on ebay the other night and some one had a set of allen headed screws with the same thread size for sale for the carb float bowls. I didn't buy them and now they are gone. Does any body know what the screw size is? I might be able to find the allen head screws locally.
Thanks Bruce
Thanks Bruce
hey PC,
those screws are very common,you can get at any ACE hardware, even in allen heads. just pull one off and take it to the store with you.
tip: on the sticky ones you should use needle nose vice-grip pliers to first break the screw loose, or an impact screw driver. i got all allen heads on mine now, that oem screw was a very soft metal, i also think Yamaha hired a Sumo wrestler to put them on at the factory. that same wrestler put my engine oil drain bolt on.
good luck
rfc
good luck
rfc
Yakuza
- Burlingame, California
- See sig
Here ya go- Allen screws 16 pcs. M4x0.70x10mm
Hope this helps.
Hope this helps.
eman
I just got 100 at Fastenal for about $10.00. Everything is gonna have the allen head. I'm done with phillips
Eman
Eman
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
Thanks guys, picked them up today at Fastenal. 16 for $1.98
Probably could buy a couple from Yamaha for that.
Bruce
Bruce
eman
From Yamaha $1.98 try maybe 1.
