Flyweight bushing options
fourbarrel
Building a collection one sled at a time
New Brunswick
Canada
2019 SRX
I am at the point where the flyweights, at the very least, will need to be changed on my '19 SRX primary. Right now the roller bushings are still good but I may change them to keep the tolerances the same between the weights and rollers. Is there any decent aftermarket options for bushings? In the past I have stuck to oem clutch parts but figured I'd post this up and see what others are using.
Hurricane Performance used to sell them , but you’ll have to run a 8mm reamer through them once presssed in.
Just pick up a new take off set of weights. Everybody takes them out right away. We found the ramp profile wears with some time on them.
