RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
How many have a high mileage viper? Mine has 6000 miles and the back of the sled footwell where it connects to the tunnel powder coat swelled up and chipped all off! Anyone have this happen to them? I'm considering putting skinz running boards on. I'm really upset this happened.. You think Yamaha would step up?
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
I had this happen as well on my 14 white ltx after first season
Im In the process of removing for powder coat for this season
Is it on the brake side? If so the brake fluid will do that. Mine looks pretty rough everywhere. White shows everything. I use a white paint pen to touch it up in some spots.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
I've already started to clean it up. Might buy new ones if they come coated again. Otherwise I may pull the rivits and have them redone.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
The other side as well its bubbled and you can push on it and it's completely separated.. Shaking my head this shouldn't be.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
They call them out in the microfiche as "gussets"
Muffin
- Oct 5, 2006
- Marathon, WI
- 2014 SR Viper RTX SE
I love the painted parts but they should be powder coated and not painted. What were they thinking?
Mine has some of that bubbling on the upper part of that brace too. It may be powder coated. Must be corrosion of that casting causing it. Probably bad prep.
apexgt4life
Any new feedback or ideas on this. Is it happening on newer. Got it on 3 14 in the group we ride with.
Wanted to see what others may have done to address.
Is it just the gusset that gets removed and potentially re powder coated?
YesAny new feedback or ideas on this. Is it happening on newer. Got it on 3 14 in the group we ride with.
apexgt4life
Yes to what part or all
Ty
Yes just remove and repaint or in my case I replaced both because the rivet hole on lower part that goes into running board was corroded so bad that Rivet no longer held tight. Its Pot Metal cheap light junk. Does the job but doesnt last. I see some Aftermarket runningboard kits use tubing or billet.Yes to what part or all
Ty
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Mine is the same, at least they aren't really expensive.Yes just remove and repaint or in my case I replaced both because the rivet hole on lower part that goes into running board was corroded so bad that Rivet no longer held tight. Its Pot Metal cheap light junk. Does the job but doesnt last. I see some Aftermarket runningboard kits use tubing or billet.
apexgt4life
Ok. So drill out rivets remove and repaint.Yes just remove and repaint or in my case I replaced both because the rivet hole on lower part that goes into running board was corroded so bad that Rivet no longer held tight. Its Pot Metal cheap light junk. Does the job but doesnt last. I see some Aftermarket runningboard kits use tubing or billet.
What do we do for rivets. As they are also painted.
I assume this was all painted as one from factory or do they sell color matches rivets.
Got any pics of finished product?
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
All the rivets are available, painted, from the dealer. I'm surprised and disappointed how many I've bought and replaced at least every other year on various parts of the tunnel, but if you read the manual it is part of the expected yearly maintenance.
