apexg88
So I went to install my new pilot skis yesterday and they wouldn't quite fit.. It seems the mount on the ski is an 1/8 in more narrow then the mount on the sled??
Idk if these are meant to be forced on for a snug fit or something is wrong?
rosco
you need to press out one of the mount bolt bushings and re install it from the outside of the ski sadle. This will give you the 1/8 " that you need
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
- x2
- Mine had both bushings mounted outside the ski saddle.
apexg88
duh lolThanks a buch guys
apex55
Throw on some shaper bars and you'll be glued to the trail!!
big guy
I have both bushings reversed like mentioned above. I also installed small stainless steel washers. Check here for pic. 5th post down.
http://www.ty4stroke.com/viewtopic.php? ... ki+install
