fox float pump
Mounted mine on the belt guard with bracket from Muffin works.
I have Fox Floats on my SRX and mounted a pump the same way on it.
I put mine under the hood and held it in place with the rubber strap that holds the airbox down, worked perfect.
I scabbed some pipe foam together and keep it in the rear compartment.
I have an 08 Rtx with pilots on it and was getting inside ski lift w 50 lbs in the floats does 45lbs sound about where I should be?
I ran 80-100 depending on conditions, 50 is the minimum they say you should run. More pressure will decrease inside lift but it will ride rougher.
I picked up two Velcro straps and strapped it to my spare belt. Been there for 4 years now
the Velcro straps are a quick and easy way. Looks like I will use that idea. for about $1 you can't really go wrong
