leepster
Anyone ever have the caps on the valve stems not come off? Ive ben trying to get them off without damaging them but I think i'm gonna have to cut them off somehow.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
righty tighty lefty loosy?
leepster
ah, ya. there siezed to the valve, when I turn them the whole valve turns.
yamahahaha
spray some penetrating oil in them
RtxViper
yup i have had that problem they get salt and sand in the threads then they seize up and dont want to unscrew. i just worked mine back and forth and got them to come off. now i just use the plastic ones like on your car and no more problems
shanksyamaha
I had one, I had to use pliars and did a little damage to the cap but nothing you can notice when standing up and looking at it so I still use it.. Put a little never seize on it when you put it back together.. (if you get it apart... )
ahicks
leepster said:ah, ya. there siezed to the valve, when I turn them the whole valve turns.
Let it come out. Then you can put it on the bench or in a vise so you can see what you're doing?
bottlerocket
Just take the whole valve out and soak it in a solution.ahicks said:leepster said:ah, ya. there siezed to the valve, when I turn them the whole valve turns.
