Frostbite
Guys, I synched my carbs yesterday. I synched them all up with #3 the non-adjustable one). I have my idle adjust screw all the way out and my idle is just a hair over 1,500. I can't get it any less unless I degrade the idle quality. I have the carbs synched to near perfection with my Morgan carb tune II.
So, then I went and turned on the key and stuffef my digital voltmeter into the yellow and black wires as required and I split the difference between (as freddie suggested) somewhere between .725 and .750. I set mine at .737.
My question is:
Since my idle is a bit higher than the specified 1350 (1250-1450) should I have either made it a bit higher or lower to compensate for this? I am guessing it really doesn't matter much but you just never know.
What do you think?
Frosty
My question is:
What do you think?
Frosty
SUPERTUNER
Frostbite said:Guys, I synched my carbs yesterday. I synched them all up with #3 the non-adjustable one). I have my idle adjust screw all the way out and my idle is just a hair over 1,500. I can't get it any less unless I degrade the idle quality. I have the carbs synched to near perfection with my Morgan carb tune II.
My question is:
What do you think?
Frosty
Frosty, you are simply sitting at idle with a very, very slightly advanced ignition timing setting. I my humble opinion, I would have to say that there is no performance gain or loss regarding this.
Happy New Year!
Freddie
Frostbite
Thanks for easing my concerns Freddie. I feel better about it now. Happy new year to you too, and thank you for making your expertise available to the rest of us yoddleheads.
Frosty
Frosty
guardrail
A few posts back Ted said to try another tps if you're not sure if its bad. If you don't have a spare to try, use an analog ohmmeter. With the tps unplugged check the resistance aross the same 2 wires that you checked the voltage. Slowly operate the throttle through is full range. The needle on the meter should move smooth through the whole range without any dips or erratic movements.
When you release the throttle it should go back to the same reading everytime.
SUPERTUNER
guardrail said:A few posts back Ted said to try another tps if you're not sure if its bad. If you don't have a spare to try, use an analog ohmmeter. With the tps unplugged check the resistance aross the same 2 wires that you checked the voltage. Slowly operate the throttle through is full range. The needle on the meter should move smooth through the whole range without any dips or erratic movements.
Thanks for weighing in on this one guradrail! Good advice indeed!
Freddie
